Order Farmall Cub Parts Online
Shiting lever on Farmall Cub
alaskapete
06-02-2002 14:02:39
Today as I was shifting gears on my Cub, the lever came out in my hand. How do I repair it? Thanks
Paul Vance
06-04-2002 21:07:35
 Re: shiting lever on Farmall Cub in reply to alaskapete, 06-02-2002 14:02:39
What are you eating?
alaskapete
06-05-2002 16:01:51
 Re: Re: shiting lever on Farmall Cub in reply to Paul Vance, 06-04-2002 21:07:35
My apologies to everyone. Obviously I was in too much of a hurry to get my problem before the public. I am sorry for misspelling a key word.
George Willer
06-02-2002 19:44:18
Are we really talking about the shifting lever?
Assuming you really mean repair, rather than replace (always my choice), you will have to remove the tranny top. You will find the shift gate in a removeable cup on the bottom of the top. Above that is a steel hemisphere that should be welded solid to the lever. Dismantle the pin, spring, and cup washers from the lever and weld or braze the inner hemisphere back in its' original place on the lever. It must be straight.
If you have all the correct original parts, you can re-assemble the lever using a proper O-ring above the outer hemisphere beneath the first cup washer to create a WATERPROOF seal. Most guys seem not to know this.
George Willer
alaskapete
06-03-2002 04:11:11
 Re: Re: shiting lever on Farmall Cub in reply to George Willer, 06-02-2002 19:44:18
Thanks for your help.
