Farmall 544 transmision trouble
Andrew
06-03-2002 02:46:57
At times my transmission (shifter) gets stuck in some strange gear. When I let out the clutch it just stalls. I cannot move the shifter, not even to neutral.
If I fool with it for a while, and let the clutch out, it comes back to "normal".
I am careful to put it in neutral before shifting to another gear, and alway stop before shifting.
Can nyone help me resolve this problem?
RPM
06-03-2002 12:42:02
 Re: Farmall 544 transmision trouble in reply to Andrew, 06-03-2002 02:46:57
Most likely its the cross shaft that the shift lever operates, its common with older tractors, 544/656/666 had same set-up, part 534120R91 has a pin that wears or slides out of place, its best to replace it with the newer part, old design had a round pin, new design was a square pin.
