Newbie Questions
Aaron
06-06-2002 18:23:57
Just got a Farmall H. Who carries parts for these tractors? Where can i find a manual with good info? What is the best way to go about getting one of these unsiezed? Who carries the correct color paint for this tractor? and Finally what would one of these be worth with new paint tires tubes and with a sickle mower?
Thanks Aaron
Aaron
06-07-2002 19:21:24
 Re: Newbie Questions in reply to Aaron, 06-06-2002 18:23:57
We got the tractor pulled home today. We have it down to the head and have found the two middle pistons are the ones that are siezed. The motor was gone through just before the tractor was parked. Did these tractors come new with sleeves. I didnt think they did but it appears this one has them.
Thanks Aaron
howard
06-08-2002 18:46:46
 Re: Re: Newbie Questions in reply to Aaron, 06-07-2002 19:21:24
yes aaron, the h is a sleeved motor
Haas
06-07-2002 03:49:55
I have some Farmall H parts, and also parts for some older IH McCormick mowers. Need to know specifics on your needs.
sammy the RED
06-07-2002 03:42:12
Who carries parts for these tractors? Your local Case/IH dealer.
Where can i find a manual with good info? Your local Case/IH dealer or Binder Books.com
What is the best way to go about getting one of these unsiezed? Lots of oil in cylinders or tear down motor.
Who carries the correct color paint for this tractor? Your local Case/IH dealer.
Finally what would one of these be worth with new paint tires tubes and with a sickle mower? Value will vary by location.
Nice Post Sammy
06-07-2002 06:56:24
 Re: Re: Newbie Questions in reply to sammy the RED, 06-07-2002 03:42:12
Thanks. ;)
Nice Post Sammy
06-07-2002 06:54:55
Thanks. ;)
David Ransom
06-06-2002 22:27:23
I don't think you will get the same answers from everybody. I've been asking such questions about a JD 50, and it seems that the only thing people agree on is chances are they're not all equally stuck...
howard
06-07-2002 18:18:10
 Re: Re: Newbie Questions in reply to David Ransom, 06-06-2002 22:27:23
never found two alike yet.
farmallgod
06-06-2002 19:16:15
Any of your local Case IH dealers can help with parts,paint and whatever you need. As far as the engine being stuck it depends on if the engine is just seized up or if there is an internal problem have you had the oil pan off of it yet that will expose the whole underside of the motor, was there water in the oil? My 2 cents.
