Farmall h question
Bob
06-08-2002 09:51:51
Is it normal to have to keep the choke half closed when first started up for about 10 to 15 seconds on farmall h. If I don't do this it will stall. This is a newly rebuilt motor. Runs fine after the few seconds of choke. Any ideas would be appreciated! Thanks Bob
Old Hand
06-08-2002 14:20:28
 Re: farmall h question in reply to Bob, 06-08-2002 09:51:51
If you don't have to choke it on start up the carb is set to rich. Just my opinion.
Steven@nd
06-08-2002 11:22:02
Sounds normal. Every tractor is a little bit different. If I choke my H at all it will flood instantly. Just pull throttle back and start it up.
Steven
The Red
06-08-2002 09:59:53
Bob that would be pretty common in my experience. I usually do 2 or 3 cranks on full choke then no choke and my Hs and M come to life. Then I usually have to fiddle with the choke for the next 20 to 40 seconds depending on how cold it is.
howard
06-08-2002 18:35:38
 Re: Re: farmall h question in reply to The Red, 06-08-2002 09:59:53
yeah, that's what the choke's for. on my old m at twenty below I keep it partly choked for quite a while.
