6 volt or 12 volt ???
Bill
06-08-2002 13:55:15
Can anyone tell me how to determine if my electrical is 6 volt or 12 volt. I can not read the tag on the starter, and there are no tags on the distributor or the coil. Thanks. The tractor is a Farmall "C" but I do not know if the electrical is original.
Red Raider
06-08-2002 18:17:14
 Re: 6 volt or 12 volt ??? in reply to Bill, 06-08-2002 13:55:15
Look under the regulator, they usually are labeled whether 6 or 12 volt.
CNKS
06-08-2002 14:37:44
Does it have a battery? 3 fillercaps = 6 volt, 6 filler caps = 12 volts. Most 12 volt conversions use an alternator, if it has a generator it is probably 6 volt, although generators can be rewired to 12 volt. the C came from the factory as 6 volt.
Bill
06-08-2002 15:52:42
 Re: Re: 6 volt or 12 volt ??? in reply to CNKS, 06-08-2002 14:37:44
CNKS, Thanks for the information, but has no battery. Any other ideas? Thanks again.
Lee_Tex
06-08-2002 16:13:17
 Re: Re: Re: 6 volt or 12 volt ??? in reply to Bill , 06-08-2002 15:52:42
Does it have a generator or altenator. If it does not have a generator then it is 12 volt.
Bill
06-08-2002 16:16:01
 Re: Re: Re: Re: 6 volt or 12 volt ??? in reply to Lee_Tex, 06-08-2002 16:13:17
Hey Lee, It does have a generator. Thanks.
