Order Farmall Cub Parts Online
Cub Generator belt #
Albanymain
06-09-2002 22:12:25
Help,
1954 Farmall Cub
My generator belt (original probably) self destructed and I don't have a number for a belt to replace it. My local tractor parts place had the same reference number for the generator as the fan, nope!! fan is a flat belt not a v and it looks to be about twice as long as the generator belt. BTW if anyone also has a belt number for the sicklebar attachment I could use that as the attachment I bought had none with it.
Thanks
Albanymain
06-12-2002 04:40:33
 Re: Cub Generator belt # in reply to Albanymain, 06-09-2002 22:12:25
Thanks to Busdriver and resources found on this webpage, I was able to successfully get the correct Gen belt for my tractor!!!!!
Bus Driver
06-10-2002 05:02:53
There are 2 numbers for the generator belts for the Cub. I suspect, but have not verified, that the differences between the 2 are minor. For tractors with serial # 165152 and below, the belt number is 351 321 R1. For serial #165153 and above and for all LoBoys the belt number is 358 213 R1.
