Need help with live pto on a super mta
Bill L
06-11-2002 18:15:44
I was runinng a brush cutter and turned to sharp and put the pto shaft in a bind it made no noise but the pto stoped turning i took out the whole pto and looked for a brocken shaft did not see one checked the pto clutches out they were not to metal but one showed some good wear so i replaced
just one.
put it all back when i ingage the pto it turns slow and i can stop it with my hand we checked it befor we put any oil back in just in case i have to take it back out. only ran for a minute or less
joe
06-12-2002 07:03:01
 Re: need help with live pto on a super mta in reply to Bill L, 06-11-2002 18:15:44
did you get your PTO bands tightened up again after you rebuilt it? I assume it is the type with the reactor bands like on the 300/350/400/450 series?
randy hall
06-11-2002 18:53:52
you might want to check your pressure plate splines and the ipto drive gear.
Steven@nd
06-11-2002 18:48:53
You may want to check the seasonal disconnect under the belly of the tractor. They have been known to break before. Look for a plate that has a lever with 2 bolt holes in it. Take that plate off and have a look up in there.
Steven
bill l
06-12-2002 16:41:38
 Re: Re: need help with live pto on a super mta in reply to Steven@nd, 06-11-2002 18:48:53
steven
how do i replace the seasonal shaft
