Farmall C ?
Brian O
06-11-2002 19:22:54
I was recently given a Farmall tractor. I think it is a model C. The model number says FC and the serial number is 128671. Can someone help verify the model and year it was made? Thanks for your help.
William Ransom
06-11-2002 19:27:56
 Re: Farmall C ? in reply to Brian O, 06-11-2002 19:22:54
That's a 1951 Super C.
Brian O
06-11-2002 21:00:23
 Re: Re: Farmall C ? in reply to William Ransom, 06-11-2002 19:27:56
Thank you Mr.Ransom for the information. I'm curious what the difference is between a 'C' and 'Super C'? Can you please explain. Thanks again.
David Ransom
06-11-2002 21:16:12
 Re: Re: Re: Farmall C ? in reply to Brian O , 06-11-2002 21:00:23
I'm sure the experts can tell you more, but the Super C had a slightly bigger engine than most plain Cs.
Ernie Bob
06-11-2002 22:30:19
 Re: Re: Re: Re: Farmall C ? in reply to David Ransom, 06-11-2002 21:16:12
Besides the larger engine they had a larger radiator, taller front grill, gas tank was higher to match up with the taller radiator, angled back brake and clutch pedals, disk brakes and the Super C had the 2 point hitch option. There might have been more but I can't think of any at this time.
kjm
06-12-2002 20:11:54
 Re: Re: Re: Re: Re: Farmall C ? in reply to Ernie Bob, 06-11-2002 22:30:19
and a water pump.
