What is an IH 37T Baler
Brian Schmidt
06-11-2002 20:29:09
How old is an IH 37T baler? Is this a square or round type? How big of a unit is it? I want to run a baler with my '49 C and would like some help picking one out.
Thanks,
Country Boy Farmer Wanna Be
Carp
06-12-2002 08:57:39
 Re: What is an IH 37T Baler in reply to Brian Schmidt, 06-11-2002 20:29:09
I have a 37 as well. They are good balers. Around the early 60's as far as age goes. The only real problem you might get from the knotters is a dull twine knife or grooves worn in the duck bills.
Sven
06-12-2002 11:25:41
 Re: Re: What is an IH 37T Baler in reply to Carp, 06-12-2002 08:57:39
Carp,
You're right about those knives, after I sharpened mine it cut like a charm. I heard alot about how great the NH and JD balers are but the IH 37 was the right price and does the job.
Sven
06-12-2002 07:30:06
I've got a IH37 baler, yes its a small square baler. Mine works fine, needed a bit of work when I got it but works fine. I've run it from a 300Utility and a W-6 no problem. Don't over feed it and you should be ok.
joe
06-12-2002 06:54:44
I've never run one of the things, but my guess is that it would really give your little C a workout. I think the bad reputation of older IH balers was that parts would wear bad and there would be problems with the knotting mechanism or something.... It had something to do with stopping the production of a bale and tying it. I would try this one out to see how it works before you pump too much money into it. JD 14T's and 24T's are probably the most widely used old balers
TomH
06-11-2002 23:25:08
It's a small square twine baler. I don't know when they were made but it was a while ago. You could pull it with a C as long as you are dropping the bales on the ground, I don't think you could pull a wagon with any baler. Older New Holland or JD balers seem to have a better reputation than IH, but condition varies at that age. I have a 27T that works okay but I think there are better choices out there.
