Need help fast super mta stoped turning
Bill L
06-12-2002 16:34:44
Boy I need this tractor running for haying season
if ever stops raining
I was running a brush cutter and the pto stoped
need help
I put a new used clutch in it no luck.
Dan
06-12-2002 18:25:51
 Re: need help fast super mta stoped turning in reply to Bill L, 06-12-2002 16:34:44
I would bet the seasonal disconnect coupler broke. It is located up under the cover where the seasonal disconnect lever lies., near the back of the TA housing on the bottom. I had mine fail while running a baler last year, no noise pto just stopped. I replaced mine with a solid coupler Worst part of it is you gotta split it between transmission case and TA unit to replace, only have to move it apart a short distance but still have to disconnect a bunch of stuff and support both ends. You can pull the cover off, will have to drain some transmission oil but not all to get a look at it. Good luck.
