Farmal Super A hydraulic leak
Brad Harper
06-12-2002 17:21:42
Hi. I recently posted a similar problem but have since replaced the gasket and O rings and have noticed an additional leak on one of the 2 tubes that lead between the reservoir and the pump. It appears that the tube has a small hairline crack when it turns to join the flange on the reservoir.
Can I fix it by propane torch and solder(remove first of course) or does it need a steel/ brass weld.. I have a wire feed welder and access to an oxy acetylene torch...Any recommendations would be appreciated as I do not do this sort of thing for a living.. I am a rookie at this...
Brad Harper
03-13-2003 13:12:42
 Re: Farmal Super A hydraulic leak in reply to Brad Harper, 06-12-2002 17:21:42
I could not get a torch but was able to get a wire feed welder... It worked fine but had to grind down the rough spots...
BIG JOHN
06-12-2002 18:40:22
To much pressure for solder. You will need to braze it with the acetylene. rig.
Brad Harper
06-20-2002 06:35:02
 Re: Re: Farmal Super A hydraulic leak in reply to BIG JOHN, 06-12-2002 18:40:22
The welding was successful. No leaks from the hydraulic system!
Brad Harper
06-17-2002 05:19:52
Thanks...I purchased some brazing sticks and will have the torch in hand ... Will do this today...
