Cracked head on B
Bill Ramsey (bi
06-16-2002 20:28:05
Well I started rebuilding my B have 2 busted blocks so found good block and started tearing everthing down today and darned if both heads have cracks in them. My question have any of you guys used a head with crack in water jacket. The cracks are between 2 water holes on the manifold side and don't go into combustion chamber. Do you think maybe it is usable? Any suggestions. Thanks a bunch.Bill
Diesel Don
06-17-2002 10:24:30
 Re: cracked head on B in reply to Bill Ramsey (bigcer), 06-16-2002 20:28:05
I recently had the head for my '34 Chev truck metal spray welded.The crack went through #2 exhaust valve seat.They repiared the crack and because of the location of the crack they needed to install a new valve seat insert.I had them go ahead and do all the valve seats.Whole job cost was $350.The tractor head may be cheaper because it is only a 4cyl.Just trying to give you an idea of how much you will pay for a repair job.The good thing about going this route is you will be almost sure of getting a repair that will work because they clean the head by hot dipping and pressure test it when completed.They can also do some testing to assure there are no other cracks that are not readily visible.
gene b
06-17-2002 04:26:28
maybe wer are tied as to who has the most cracked heads i have not used any yet but my valve grinding guy says he has some stuff that will seal a crack like that up have two that are that way sometime when i make another engine for myself i will try it dont see any reason that it wont work yours propably cracked cause the block was full of junk and couldnt cool decent go for it as would cost 300 for reconditioned head
06-17-2002 09:46:24
 Re: Re: cracked head on B in reply to gene b, 06-17-2002 04:26:28
Geez that's hard to read with no capital letters or periods.
rhouston
06-17-2002 10:36:36
 Re: Re: Re: cracked head on B in reply to ???, 06-17-2002 09:46:24
thatstractorspeak
