Farmall A misses under load and pops through exhaust
Bryan Meade
06-18-2002 10:32:09
i have a Farmall A that starts giving a little "floop" noise out the exhaust under a load or pull. this i killing my power. heres what i have already tried.
1. new points
2. new plugs/wires
3. new used govenor from my parts tractor which was a better one than mine.
4. 2 year old working carter carb from my dads tractor
5. new 12 volt coil and resister for it.
what is going on? im not a farmall expert by no means, but i do have a good sense for mechanics.
gene b
06-18-2002 19:57:14
 Re: farmall A misses under load and pops through exhaust in reply to Bryan Meade, 06-18-2002 10:32:09
better check you wires and rotor to see if everything is in order sounds like things arent lined up correct
bryan meade
06-18-2002 10:34:10
when this "floop" noise/miss hapens at night i can see a flame about 2 inches coming from the muffler. this is a new muffler made for this tractor, but problem existed before the muffler change.
jal-SD
06-18-2002 10:54:35
 Re: Re: farmall A misses under load and pops through exhaust in reply to bryan meade, 06-18-2002 10:34:10
Have you checked the valve adjustment? Sounds like you may have an exhaust valve sticking or a timing problem. (My $0.02 worth. jal-SD)
