Cracked oil pump casting (two of them). Farmall H
atw
06-19-2002 05:14:38
Has anybody ever seen a problem with the oil pump castings cracking just below the mounting flange (to the engine block)on Farmall H tractors. I pulled the oil pan off my H and noticed the pump was cracked, so I bought a used pump to replace it. When I cleaned the grime off the new pump I discovered it was cracked in the same exact place as the old one. The pumps are fully functional, just cracked. Common problem, or do I have two bad pumps? Could I just have the crack welded?
joe
06-19-2002 09:43:41
 Re: Cracked oil pump casting (two of them). Farmall H in reply to atw, 06-19-2002 05:14:38
I had a 300U pump crack like that, but it was because a stump collided with the oil pan... In any case, I got a new pump and that fixed the problem. I have no clue as to how many years it ran broken like that, but a few years ago it developed a knock, so i pulled the oil pan off, and the pump was busted! As for yours, if they are still in one piece, and not completely broken into two pieces, it should be an easy thing for an experienced welder to fix, and I say experienced because it IS cast iron.
