Rear tires for a Farmall
Bryce Andreasen
06-20-2002 14:35:00
I have a 1941 Farmall "H" and have replaced the two front because they were rotten and were flat. now, my back right tire has went flat and need new rims and rubber, but the trouble is that i cant find a supplier. I live in NE, around Omaha, and need 12-38's any advice possible would be apreciated. thanks
CNKS
06-20-2002 18:43:11
 Re: Rear tires for a Farmall in reply to Bryce Andreasen, 06-20-2002 14:35:00
The replacement for 12-38 is 13.6-38. OEM for an M was probably 11-38 which is now 12.4-38. 11.2-38 replaced 10-38, a little small for an M unless it was used to cultivate in narrow rows.
CNKS
06-20-2002 19:36:18
 Re: Re: Rear tires for a Farmall in reply to CNKS, 06-20-2002 18:43:11
Getting old -- brain not working, You have an H, forget wht I wrote!--except that 12.4-38 will work, that's what we had on ours when I was young and my brain worked.
tom W
06-20-2002 14:41:44
The rims you need are 12 - 38 and are avaliable at your IH dealer. About $150 each. the tires you need are 11.2 -38 and you should be able to get them at any tire dealer. About $200 each with tubes. So $700 should put new skins on the H
howard
06-20-2002 18:20:05
 Re: Re: Rear tires for a Farmall in reply to tom W, 06-20-2002 14:41:44
check around on tire prices. the 11.2 38 is used on the newer pivots and they have been advertised for $140. try Firth Coop.
