Super A Hydraulics
losing fluid into the oil
Bob
06-22-2002 07:23:49
Im losing hydraulic fluid in a big way. After a couple hours of use I cant feel any fluid in the hydraulic resevor. Anyone know where I can purchase a hydraulic pump? Or is there an alternative to replacing the pump? Thanks
gene b
06-22-2002 21:48:59
 Re: Super A Hydraulics - losing fluid into the oil in reply to Bob, 06-22-2002 07:23:49
when you take your pump out be sure you check the journal on the pumpshaft probably needs a speedy sleve so the new seal can stop the leakage
SAm in NS
06-22-2002 13:06:28
Replacing the front seal/gasket on the pump should fix your problem. Good luck. SAm in NS
Dave_Id
06-22-2002 08:32:36
Just replace the seals in the pump. It's an easy job
