Farmall h front tires
Bob
06-22-2002 13:49:50
Today the sidewall blew on my farmall h front tire. I noticed that the tires had tubes in them. When I put new ones on could I use tubeless tires or do I have to use tubes? Any help would be appreciated! Thanks Bob
Dr. Evil
06-24-2002 07:20:48
 Re: farmall h front tires in reply to Bob, 06-22-2002 13:49:50
One of the bigger complaints We had a FARMALL about tires was the fact We used tubeless tires on the front wheels.....Do Yourself a favor & put tubes in the new tires!
Roger
06-23-2002 18:46:56
Bob, I didn't know you could even buy tubeless tires that size for an H. I would be concerned that the rims would leak unless you have the older H rims without the rivits that hold the mounting lugs on, as the rivits probably would leak air. Roger
joe
06-23-2002 10:02:20
I doubt they'd do very good as tubeless - but I always go with tubes in any case, just that much easier to fix when I get a flat than tubeless tires are. Just pull the tire off the rim, put a patch on, and you are back in business!
TomH
06-22-2002 16:49:17
The rims on my H are in pretty good shape considering the age, but when I bought tires the dealer said they probably wouldn't hold air without tubes.
