B Rear Axle Seal
1PWRFULH
07-01-2002 14:33:21
The left rear axle seal on the B is leaking badly and has been for some time now. It seems to be leaking on the lower axle where the hub would bolt to. Beings I don't have a manual for tractor I just wondered how hard of a job it was to put a new seal in it and if there was anything I should be prepared for? Does that whole gearcase use oil from the transmisson or is there a whole different seperate filler for it and if so where would it be? What type/kind of oil do you recommend? I just figured I've got all the weights off of the tractor now for the tractor pulls and I should just go ahead and put the seal in now. Thanks a lot.
RC
RedBug
07-02-2002 21:22:35
 Re: B Rear Axle Seal in reply to 1PWRFULH, 07-01-2002 14:33:21
You can make your own gaskets/seals a lot cheaper the the Case dealer. Also check out your brearings while you have it torn down.
Roger
07-01-2002 19:38:11
RC, I am currently restoring a Farmall B. It just so happens I was disassembling the final drive assy tonight. The final drive assy that the axle is in has it's own oil. It is filled through a plug on the front inside of the casting. To change the oil you have to remove the lower pan. The axle is removed by taking the inside cover off and removing the bolt on the end of the axle. Then remove the four bolts on the outside seal cap. Pull the axle out from the outside. I used one of those hammer pullers attached to the outside hub as the axle doesn't just slide out. There are several washers and parts on the axle that you need to keep in order for reassembly. The final drive bull gear is about 12 inches in diameter and will come out the bottom when the axle is pulled. Then for the hard part - you have to pull the bearing off the axle. It is pressed on the axle with a fairly good press fit. I pressed it out on my hydraulic press using one of those bearing pullers to get behind the bearing cap. If you don't have anything like that you can probably take to a local auto machine shop and have them press it off. You can use regular transmission 90 weight or equal in there after you get back together. I was able to get all gaskets and seals at the local Case IH dealer. Hope that helps. Roger
