B414 info
Bama Binder
07-03-2002 06:58:12
I understand that the B414 was imported from England and is similar to the 424. I have heard good things about the tractor in general. The one I have found is a gas model in generally good condition. I need a small to medium sized utility and this may fit the bill. I also understand parts are generally easy to find.
The owner says the only problem he has is that it will the PTO will disengage occasionally on its own.
Questions:
Is the PTO potentially a big problem that would require major expense?
Is $1500 a reasonable price?
Would it make a reasonably good loader tractor if it has power steering?
Thanks for any help/info. BB
Generatorguru
07-03-2002 12:24:41
 Re: B414 info in reply to Bama Binder, 07-03-2002 06:58:12
I have a B414, and so far I have had no problems with it. I get my parts at the local IH dealership and havent run into anything that was impossible to get yet. I use mine mainly for the 3pt attachments so I dont know what to tell you about the loader. I run a 7ft Lorenz snowblower and a 7ft Buhler finishing mower for it. I will say I paid a bit more than that for it so it sounds like that is a good deal. Good luck Shawn
Cman
07-03-2002 10:03:47
It should make a good loader tractor, and the price sounds right too. Here is a place that could help you out should you need any parts.
