Timing a 1940 model Farmall A
Alvin Turner
07-04-2002 19:29:08
Just had head and valve job done . Cam is good. All cylinders are firing, but the #4 cylinder is popping back through the carbureator. Could this be the timing? If so, how do we time one of these tractors? This tractor has the magneta instead of a distributor.
Would appreciate any help you could give me. Thanks. E mail me at my personal email, please. cturner1@kih.net.
Alvin
Alvin Turner
07-05-2002 19:33:18
 Re: Timing a 1940 model Farmall A in reply to Alvin Turner, 07-04-2002 19:29:08
I have tried changing the plug wires. We had the head cleaned and the valves seated, but it is still 'popping' out the carbureator. If I take the back or #4 plug wire off it doesn't pop. Nothing else I tried makes it stop. Any more suggestions?
Alvin
Diesel Don
07-05-2002 14:33:21
Brian gave you a good start.If by chance this won't work,recheck your tappet clearance.#4 intake may not be seating.It is a good idea to set the valves .002 over the hot setting and then resetting them hot once you have run the engine a while to let things settle in.
Brian
07-04-2002 20:05:55
Well I don't know how you figure it's #4 cylinder, but mine did the same thing and it turned out that I had 2&3 reversed. The rotor turned the opposite direction than what I thought it did, and therefore the order was slightly off.
My thoughts.
