Farmall h
aggirl31
07-07-2002 09:05:30
Have a farmall h that run the last time we pulled it to mow a couple of years ago.Long time ago when mil lived here a man stopped by said the seat was worth something,didnt make them like that for long or something. Is it worth the trouble too try to sell? live in sw ne.
Steven@nd
07-07-2002 12:36:33
 Re: farmall h in reply to aggirl31, 07-07-2002 09:05:30
If the fella said that they didn't make the seat like that for long I would bet it is a 1939 model or early 1940. If so it should have a low serial number.
Post back with serial number or pics and we can help out.
Steven
The Red
07-07-2002 11:07:04
Prices on Hs can vary from a barely running one at $500 to a nicely restored one for $3,500. See if you can find a serial number. There should be a plate under the oil bath air cleaner on the clutch housing. Also the engine serial number will be stamped on a flat surface above the #1 spark plug. That is the one closest to the radiator.
It would be a tremendous help if you could post a picture.
BIG JOHN
07-07-2002 13:49:31
 Re: Re: farmall h in reply to The Red, 07-07-2002 11:07:04
Red, isn't that engine number just below the #1 plug on the block rather than the head????
The Red
07-07-2002 14:16:14
 Re: Re: Re: farmall h in reply to BIG JOHN, 07-07-2002 13:49:31
Could be John. I know it is either above or below!! Can't miss it!! :)
