Farmall h carb packing nut?
Bob
07-09-2002 10:21:07
i have a 1942 farmall h with a gasoline engine and I am in the process of rebuilding the carb and when I took the packing nut out ( goes between the main adjutment needle and seat) it was completly crushed. I put the new one in and crushed the new one while tightened down the brass fitting that goes above it. I was wondering should I have put the needle in before I tightened the brass fitting down? Do IH dealers sell this packing nut seperatly or do i have to buy a whole new kit? How tight does the brass fitting have to be? Any help would be appreciated! Thanks Bob
MARV
07-10-2002 19:24:48
 Re: farmall h carb packing nut? in reply to Bob, 07-09-2002 10:21:07
I am pretty sure that the packing is avail seperate at the IH dealer, at least it is for a Super H as I did the same. your not alone Marv
Bob
07-10-2002 20:10:18
 Re: Re: farmall h carb packing nut? in reply to MARV, 07-10-2002 19:24:48
Thanks for the info! I am going to check with my IH dealer tommorow. Thanks Again Bob
The Red
07-09-2002 11:57:37
Bob from experience, I NOW stick the needle in first and adjust it to about where it was before the rebuild. I then install the brass nut and tighten down on the new packing material. Did it your way once and had to dig out the material and start all over. :(
Travis
07-10-2002 18:54:28
 Re: Re: farmall h carb packing nut? in reply to The Red, 07-09-2002 11:57:37
I agree with Bob. Just rebuilt my H carb and had to get a second kit just for that lousy packing nut. Put the packing nut in, put the brass nut and needle in, then tighten and adjust.
