Farmall h float level?
Bob
07-09-2002 18:18:28
Can someone tell me the proper float level for a gasoline farmall h? Also where should I measure the level from? the front or the back of the float? Should I measure the gap with gasket on or off? Should I use a drill bit to get the proper gap? Thanks Bob
Travis
07-10-2002 18:43:17
 Re: farmall h float level? in reply to Bob, 07-09-2002 18:18:28
Hold the carb body so the float hangs at its lowest position. Measure from rim of body (no gasket) to lowest point on float. Use a vernier scale if you have it, a good ruler otherwise. Should be 1 inch and 27/32, plus or minus 3/64. Hope this helps.
Farmall Don
07-09-2002 19:00:46
1 13/32
I measure from the top of the bowl casting to the bottom of the float. I have a picture in my manual that illustrates measuring it from the front of the float and it also illustrates the gasket being on. I dont understand the drill bit procedure, but maybe someone else can be of better assistance. I only know enough to be dangerous??
Farmall Don
07-09-2002 19:03:16
 Re: Re: farmall h float level? in reply to Farmall Don, 07-09-2002 19:00:46
Correction 1 53/64, sorry I looked at the wrong column in my manual. 1 13/32 is a cub.
Bob
07-09-2002 19:16:21
 Re: Re: Re: farmall h float level? in reply to Farmall Don, 07-09-2002 19:03:16
Don,When you say 1 53/64 does the 1 mean 1cm or 1mm? I am sorry, I am new to carb rebuilding. Thanks Bob
ONE INCH
07-09-2002 22:36:25
 Re: Re: Re: Re: farmall h float level? in reply to Bob, 07-09-2002 19:16:21
inch
Farmall Don
07-10-2002 19:33:06
 Re: Re: Re: Re: Re: farmall h float level? in reply to ONE INCH, 07-09-2002 22:36:25
Yes, that is in inches. I wish I had a scanner. I would send you a chart with a diagram I have from a Farmall letter series manual on tune ups.
Bob
07-10-2002 20:08:12
 Re: Re: Re: Re: Re: Re: farmall h float level? in reply to Farmall Don, 07-10-2002 19:33:06
thanks for the info! I will set my float tommorow. Thanks again Bob
