Spark Plugs For H
B Batty
08-16-1999 18:08:06
Anyone know the Champion spark plug no. for a '47 H?
The Red
08-17-1999 02:14:23
 Re: Spark Plugs For H in reply to B Batty, 08-16-1999 18:08:06
Having more spark plugs laying around then I have GB on my hard drive (37.5), the Champion D15Y are usually too cold and don't fire worth a darn after a short period of time. In Champion use D21Y. I now use AC with no problems. AC C86 is the successor to the AC C83.
Lyle
08-17-1999 07:35:41
 Re: Re: Spark Plugs For H in reply to The Red, 08-17-1999 02:14:23
RED,I use D-21 in H & 350. Have had the same set of D-15Y in SMTA for 5 years now, this is a working tractor, worked about a 120 acres with it last year. When the other tractors wont start, we can always depend on those D-15Y's to fire up without a problem. I think the lower power tractors, like your H's, need a hotter plug.
The Red
08-17-1999 13:34:26
 Re: Re: Re: Spark Plugs For H in reply to Lyle, 08-17-1999 07:35:41
Lyle that could be the reason I reckon. All of ones I have messed with are 6 to 1 compression or around 100psi. Anyway at least I finally found a winning combination. They cost the same in Indy no matter which brand you buy.
Wayne
08-16-1999 18:31:00
Here we go again. Spark plug wars. Love it. D 17y rings a bell.
sammy the RED
08-16-1999 19:49:47
 Re: Re: Spark Plugs For H in reply to Wayne, 08-16-1999 18:31:00
Manual from 1946 H that I used, says 15-A for Champion, or AC-87. I know that a lot of guys use D-21 because of the unleaded gas issue. I still use D15-Y in my SMTA'S have had no problems.
Don
08-16-1999 21:37:00
 Re: Re: Re: Spark Plugs For H in reply to sammy the RED, 08-16-1999 19:49:47
D15Y was the old number , think new number is 515. I prefer AC plugs, C83,.. or a autolite plug. Got away from Champion, they never last
Bob Mn.
08-17-1999 07:05:51
 Re: Re: Re: Re: Spark Plugs For H in reply to Don, 08-16-1999 21:37:00
I went also through the spark plug problem on my H and M, installed new champions with no cure for missing, put in AC 87 I believe with out looking, both run like new for 2 yr's now, any weather,now have 2 sets of champs in box taking up space in shop.
The Red
08-17-1999 07:17:18
 Re: Re: Re: Re: Re: Spark Plugs For H in reply to Bob Mn., 08-17-1999 07:05:51
Amen on that. I was a diehard Champion fan but have jumped the fence. I know from 10 seasons of experience the ACs are a far better plug. They get the Red seal of approval. :)
Ed
08-18-1999 13:28:25
 Re: Re: Re: Re: Re: Re: Spark Plugs For H in reply to The Red, 08-17-1999 07:17:18
I'll agree that Champion plugs are garbage. I've got a dozens of times when they failed - just stopped working (dead cly), middle blew right out, fouled up when and AC would not (The Autoparts store told me they were the same heat range).
For kicks what's AC stand for ?????
Albert Champion.
ALFRED CHAMPION founder of both AC and Champion
08-18-1999 19:24:00
 Re: Re: Re: Re: Re: Re: Re: Spark Plugs For H in reply to Ed, 08-18-1999 13:28:25
No kidding..... .. sammy the RED
sammy the RED
08-16-1999 22:44:55
Just helped a freind put D-15Y plugs in his 450 that he had bought at the local CASE/IH dealer friday !
