Fuel tank sealant ? Help!!
Bob
07-12-2002 11:14:30
I just got my sealing kit from Por-15 and I was wondering when I put the sealant in will it plug the fuel shut off assembly? I tried taking the assembly off but it won't come off and I don't want to try anymore in case I break it. If it does plug it is there a way I can clean it while it is still on the tank? Any help would be appreciated! Thanks Bob
PaulH
07-12-2002 13:58:50
 Re: fuel tank sealant ? Help!! in reply to Bob, 07-12-2002 11:14:30
I used the POR-15 kit on a tank for an M. I removed the outlet valve assembly, but I think you could go ahead and put the stuff in, then be sure to blow the valve out thoroughly (from the outlet) with an air hose, after distributing the sealant. I don't know, however, how you're going to get the tank clean and dry with that valve hanging on the bottom. It takes a lot of shakin' and rollin'. It would be much easier to get it out first.
