584 braking problem
At wits end
07-18-2002 07:21:33
I have a 584 with brake problems. I am getting air into the brake system some where. I have to bleed the brakes every couple of days and then i have good brakes until it sits maybe a couple days then the same routine .Any sugg. on where to start looking. I thought it could be the master cyl.but woulld both sides be bad or couldone side be leaking to the other .
RPM
07-20-2002 06:42:40
 Re: 584 braking problem in reply to At wits end, 07-18-2002 07:21:33
Brakes on 74/84/85 series were not my favorite to fix, they have a brake equalizer valve, and cyls for each brake side, then the orings on the actual piston that is mounted on inner end of axle. The brake cyls can be resealed, the equalizer replaced, then remove the axle & housing to replace the orings on the actuator piston.
