460 Parts
Andrew
07-18-2002 08:26:21
Are most of the parts for a 460 and 560 interchangable such as sheetmetal and the like. Are the rearend gears and stuff? I know the engines are different. Just wondering what else was.
HD
07-21-2002 12:12:23
 Re: 460 Parts in reply to Andrew, 07-18-2002 08:26:21
The engine block and heads are the same on 4-560's only difference was crankshaft and pistons . The 560 had a longer throw and different pin location in the pistons
Rear ends are not interchangeable 560 is a heaver rear end and housing is different and not sure on hood and side pieces
jt
07-18-2002 13:10:47
the rear ends and trans are different only a few bearings and seals will crossover all sheet metal is the same exept for hood and white pieces under hood
Bryan
07-18-2002 13:03:54
I believe the 460 and 560 rearends are different. Somebody correct me if I'm wrong, but the guts of the 560 rearend are the same as the M while the 460 has H parts. The sheetmetal is the same and most of the other cosmetic stuff is also. The similarities stop once you take the sheetmetal off though.
