Farmall h oil pressure?
Bob
07-19-2002 16:57:10
can anyone tell me what the proper oil pressure for a farmall h is at idle and full speed? Thanks Bob
Travis
07-19-2002 20:19:37
 Re: farmall h oil pressure? in reply to Bob, 07-19-2002 16:57:10
My 1940, never rebuilt, pegs the oil pressure gauge at idle. Just bought this tractor, and I think "That ain't right"! Same before and after oil and filter change. Probably a bad gauge?
Travis
Doug in OR
07-19-2002 22:00:48
 Re: Re: farmall h oil pressure? in reply to Travis, 07-19-2002 20:19:37
Yes, I'd make certain the gauge isn't the problem. If the gauge is good, I'd not hesitate to look deeper. You don't want a bad pressure relief valve that allows too much oil pressure.
I've said it before.. I'll say it again... low oil pressure with oil circulation hurts nothing. High oil pressure and no circulation, or circulation blocked to certain engine components, can be doing all kinds of nasty little damage.
BIG JOHN in KS
07-19-2002 17:52:17
Bob, all the service manuel says is that the pressure relief valve spring is set to 60 - 70 lbs of pressure.
Larry F
07-19-2002 19:55:00
 Re: Re: farmall h oil pressure? in reply to BIG JOHN in KS, 07-19-2002 17:52:17
I'm getting 70 lbs. oil pressure on my new H rebuild.
