706 two point hitch spongy
bryan
07-20-2002 09:50:17
I had my TA replaced and when it was split they noticed that the reverse driven gear was missing teeth from the parking brake. We'll they took the seat frame and the hydralic lifting housing off to repair it. My 2 point worked great before this and now I can not adjust it heavy or light and it only lowers slightly and the hitch is very spongy. We you stand on it you can bounce up and down on it like it is attached to a spring which is not right. Does air in the system make it spongy and is the a linkage out of adjustment for the load sensing control.
smotch
07-21-2002 15:03:51
 Re: 706 two point hitch spongy in reply to bryan, 07-20-2002 09:50:17
Bryan, Remove the plate at the back of the tractor to gain access to the sensing arm and make sure that the draft sensing arm is in the right position. The lever from the rockshaft cover goes behind the arm that comes up from the torsion bar at the bottom of the differential case.If this is in the proper place turn the sensing arm adjusting screw clockwise3 to 4 turns place the draft control lever 2 7/8 inches from the rear slot of the quadrant, move the position control lever to the lower position (at offset in quadrant)Start engine and turn adjusting screw counter-clockwise until the hitch raises The hitch will raise all the way . tighten the set screw and replace the cover .
bryan
07-21-2002 19:36:41
 Re: Re: 706 two point hitch spongy in reply to smotch, 07-21-2002 15:03:51
That worked great. It works great now Thanks
