574 International D239 Oil Breather problem
Bob D
07-25-2002 12:38:57
I have a 574 With a D239 motor. I have a problem
with oil blowing out the breather tube when
going up a steep incline. International used to
make a kit to fix this problem, but it is no longer available. Does anyone know how I can fix
this or a part number for a new type of Rocker
cover with a breather in it to fit my D239 motor.
Thanks Bob D
Alton
07-25-2002 13:47:53
 Re: 574 International D239 Oil Breather problem in reply to Bob D, 07-25-2002 12:38:57
How long have you had this tractor and have you had this problem all the time? If it has a lot of hours on it you might want to check and see if the oil return holes in the head are stopped up. You may have excessive blow by on the crankcase you should check for this. If your tube is in the rocker cover. If it is on the side lifter cover you may need to fabricate a baffle over the hole so oil won't get to it.
Bob D
07-25-2002 14:05:18
 Re: Re: 574 International D239 Oil Breather problem in reply to Alton, 07-25-2002 13:47:53
There is no problem with blow by the tractor was
just overhauled. This problem only exists when going up steep grades at 3/4 throttle.
