Can I Put a M Widefront on any M
38G
07-27-2002 13:37:47
I want a widefront for my M but don't want to sell the M i have...It is a normal 2 wheel tricycle row crop know. Does Farmall's M d\widefront just bolt right on or not?? thanks you all are great
Norm
07-28-2002 01:53:36
 Re: Can I Put a M Widefront on any M in reply to 38G, 07-27-2002 13:37:47
Get one for a 560 or newer. Then you can use the newer style Hubs with floatation tires. These are much better.
Hugh MacKay
07-27-2002 18:45:08
Any front end from an M should fit. Front end from SM, 400, 450, 560, etc will also fit. The newer front ends had tie rods behind axle and make a better set up. Easier to keep aligned, as they have ball and socket tie rods. Older front ends had pins and shackles. My dad ran into a problem once with an H narrow from factory. Some of the holes in tractor were not drilled. Was in frame rails where stabilizer bolts up.
