H motor noise
53h
07-27-2002 18:54:11
I have 2 questions reguarding my 53 H. First the rear main seal is new and leaking. The bearings for the 53 engines were the same as the super H's is the felt seal different than a regular H? It also has a slight knockig sound from the front cover the crank gear appears to be worn. Are they still avaliable?
Michael Soldan
07-28-2002 06:27:25
 Re: H motor noise in reply to 53h, 07-27-2002 18:54:11
53H, you should be able to get the gear and seals from you Case-I-H dealer without any problem.I'd try an additive to the engine for the "knocking", perhaps "slick 50" or a product like that. What weight of oil are you using?...a 30HD or a 15w40 might be better for older engines..good luck!
53h
07-28-2002 09:51:41
 Re: Re: H motor noise in reply to Michael Soldan, 07-28-2002 06:27:25
I used 30 wt oil and I have the motor out so I want to change the gear. The rest of the motor is new. Thanks for the info.
