Brakes hang up and 12 volt conversion.
Bob G
07-29-2002 08:10:35
I have an M that the left brake hangs up. I just got it home so I haven't had time to do anything to it. Any suggestions of what to do?
I would also like to convert to 12 volt can someone point me in the right direction of the parts I need and how to convert it.
Thanks,
Bob G
Michael Soldan
07-29-2002 17:04:09
 Re: Brakes hang up and 12 volt conversion. in reply to Bob G, 07-29-2002 08:10:35
Bob you will need to remove the brake pans, what you likely have is a brake band shaft seized into the tractor. There should be a brass bushing in the hole into which the brake band shaft goes. I have seen the bushing almost worn away and the shaft rusted in. Soaking in penetrating oil , heating and moving the brake band arm will eventually work it loose. You need to clean the hole, put a new brass bushing in and lube the brake band shaft with white grease. I had one on an H and it took two of us almost 4 hours to unseize it and get the brake band shaft out...hard to believe something can seize that tight...good luck from Mike in Exeter Ontario
Michael Soldan
07-29-2002 17:04:09
The Red
07-29-2002 11:22:19
On that hanging left brake, do you mean the pedal is not returning to the deck edge?
On 12 volt conversion, do you want to stay with a 12 generator/voltage regulator, or go the alternator route?
Don LC
07-29-2002 12:57:27
 Re: Re: Brakes hang up and 12 volt conversion. in reply to The Red, 07-29-2002 11:22:19
FARMALL M 12v conversion is in "Research & Info" on the left side of this page... click on "ARTICALS"----go down about 20" you will find what you need.....
Bob G
07-29-2002 12:25:46
The pedal returns to the deck. Evidently the brake band or something in the area is hanging up.
I would like to go with a one wire (GM) alternator.
Thanks,
Bob G
The Red
07-29-2002 13:15:49
 Re: Re: Re: Brakes hang up and 12 volt conversion. in reply to Bob G, 07-29-2002 12:25:46
Punch below for Bob's super diagrams and select the one you want to go with.
You will have to remove that brake cover. It is probably full of dirt!!
Bob G
07-29-2002 19:05:21
 Re: Re: Re: Re: Brakes hang up and 12 volt conversion. in reply to The Red, 07-29-2002 13:15:49
Thanks everyone for the help.
Bob G
