M oil pressure still trying
AgMan
08-17-1999 17:02:00
I plasiguaged the main and rod bearings. Someone must have replaced, they were fine. Now back to the pump! Thanks Jk Mn for the testing method I will try that tomorrow. Note: I'am beginning to question the hole where the oil is supposed to come out on the pump. Mine is irregular, is it supposed to be?
justin
08-17-1999 17:16:48
 Re: M oil pressure still trying in reply to AgMan, 08-17-1999 17:02:00
Now that we know the rods and mains are fine, I would work with the pump.. if a replacement pump doesn't fix it, i would suggest that you change the cam bearings... If your pump doesn't work, go with Reds suggestion getting a used one, but make sure that it is guaranteed.. We'll get her nailed eventually with hopefully not much in th eway of investment..
