Help with radiator removal.
Bob G
07-29-2002 19:07:53
I need to repair the pipe that runs through the radiator for the steering column. Can someone list the procedure for it. I'm assuming that you need to loosen the colar up by the steering wheel. Will the shaft slide out of the steering box in front of the radiator or do I need to loosen something.
Thanks,
Bob G
Theman
07-30-2002 08:38:03
 Re: Help with radiator removal. in reply to Bob G, 07-29-2002 19:07:53
Remove the hood and grille. Clean the steering shaft over the engine. If the shaft is covered with grease and dirt, that stuff may end up in your steering gear. Take the cast iron cap off of the front of the steering gearbox at the top of the pedestal. Disconnect the front steering shaft in the middle at the U-Joint. The steering wheel and collar can stay where they are. You can then thread the worm gear out of the front of the pedestal and pull the shaft forward.
Wayne Swenson
07-29-2002 21:00:44
What model tractor are you working on??
Bob G
07-30-2002 05:52:54
 Re: Re: Help with radiator removal. in reply to Wayne Swenson, 07-29-2002 21:00:44
I am working on a Farmall M.
