3 point hydraulic cylinders 3 or 4 inch
bobbgood2
07-31-2002 18:46:55
after reading the specification section in the IH service manual GSS-5034 for the hydraulic lift-all I need opinions on which to use and why. Two 3 inch diameter cylinders or one 4 inch. The way I figure it two 3 inch cyl. at 800-lb. of hyd. pressure will lift 11,312 lbs. and one 4 inch cyl. will lift 10,000 lbs.. Do I need the extra cyl. for general 3 point work (bush hog, bale spike, box blade, etc.)?
I'd like to hear your opinions.
Zonie
07-31-2002 20:52:28
 Re: 3 point hydraulic cylinders 3 or 4 inch in reply to bobbgood2, 07-31-2002 18:46:55
I built the 3 point on my H and used only one 3 1/2 cylinder. I wish I had done it with 2 cylinders. The hydraulics have plenty of lifting power. they will lift the front of the tractor if I'm trying to lift too much weight with the 3 point but I have bent the rock shaft due to the hydraulic cylinder being on one side. 2 cylinders would eliminate this problem.
BIG JOHN
07-31-2002 19:20:46
The model 340 Farmall came with a 2 point hitch and a 3 point adpater. It used one 4" cylinder and everything worked well. 2 cylinders would mean just one more to mantain.
