Hot coil
brad finke
08-08-2002 19:27:56
coils getting really hot on my third coil would an over charging alternator do this i am stumped this tractor is a farmall B thanks
Bob M
08-09-2002 05:06:15
 Re: hot coil in reply to brad finke, 08-08-2002 19:27:56
Brad - I presume your B has been converted to 12 volts?? If so, you're overpowering the old (6 volt) coil. Solution is to install a ballast resistor in series with the coil primary to drop the voltage at the coil to 6 volts. Insert the resistor in the wire between the ignition switch and the coil "+".
Alternatively you can replace your 6 volt coil with a 12 volt one, though this will cost more than the ballast resistor.
If you go the ballast resistor route, get a generic (Chrysler style) resistor - NAPA #ICR13 or similar. Be sure to mount the resistor to something metal on the tractor (NOT the gas tank!) as it gets quite warm when operating.
brad
08-09-2002 05:37:59
 Re: Re: hot coil in reply to Bob M, 08-09-2002 05:06:15
bob i am using a 12 volt coil with a gm alt
Bob M
08-09-2002 05:50:42
 Re: Re: Re: hot coil in reply to brad, 08-09-2002 05:37:59
Hmmmm.... Do you have a DC ammeter? If so take a current reading in the coil primary with the engine off and ignition switch on. If you read more than about 4 amps, a ballast resistor will solve your problem. However if your ammeter shows 3 amps or less, I'm stumped!!
