C Fast Hitch Prongs
Brian Schmidt
08-09-2002 19:17:24
Anyone found a supplier for fast hitch prongs to fit the small class fast hitch on a Super C? I have found the 3 point adapters. But there are quite expensive. About $95 each side. I was thinking about $20 - $30 for a pair should be about right.
I want to take a junk little genius and make a fast hitch plow since there are none out there to be had reasonable. Would be fairly easy except for the prongs.
Could have a friend burn them out on his computer burn table, but hate to waste too many favors if not needed.
Colorado Curt
08-12-2002 07:50:22
 Re: C Fast Hitch Prongs in reply to Brian Schmidt, 08-09-2002 19:17:24
Where are you located? I have a pair that are attached to a 12' tool bar that I'll sell to you for $30.
Hugh MacKay
08-10-2002 18:09:44
Best source of fast hitch prongs is old fast hitch equipment at scrap yards. I my area fast hitch equipment goes for a song. Plows or mowers $100. each. I had 4 of these made 12 years ago at machine shop and with proper taper, (they will not work without taper) and they cost me $85. Cdn. each.
cd
08-09-2002 20:28:09
find a friend with a torch or plasma cutter and a grinder, and cut them out, cheap and not real hard
