F-12 Head bolt Torque
Andy
08-10-2002 19:06:26
Could someone please tell me what the head bolt torque is on an F-12 with IH Engine?
Thanks
Diesel Don
08-11-2002 08:02:01
 Re: F-12 Head bolt Torque in reply to Andy, 08-10-2002 19:06:26
What I have done on my '34 Chev and a number of small engines is get the torque spec for the bolts off a standard torque chart making the assumption that the bolts were heat treated to some degree.With that in mind,I assume a Grade 5 bolt and measure the diameter.It then becomes a mater of simply looking up the torque on the chart.On my old truck,the bolts were 1/2" coarse thread.Torque spec was 80 ft-lbs.I would strongly suggest replacing the bolts because they do stretch.
Mary, Mary
08-11-2002 21:17:59
 Re: Re: F-12 Head bolt Torque in reply to Diesel Don, 08-11-2002 08:02:01
That is interesting. If I recall correctly the bolts were 5/8s shank. Do you happen to know what the torque specs are on such a diameter?
John (SC)
08-11-2002 05:57:51
Its somewhere in the archive but I think that the general concensus was that it was 70,same as the As,Bs and other with the 113 engine.I think i did my 14 at 70 or 75
Mary Mary
08-10-2002 22:20:18
That's a very good question. In the end after talking with a number of knowledgeabe people we determined that the proper torque was between 90-100 ft lbs. We settled on 90.
