Rear axles of Super A
Belinda
08-11-2002 08:27:28
Upon restoring my super a tractor I discovered that the only thing keeping the 600 lb wheel in is a 1/4 inch thick aluminum plate. Could anyone please tell me if this is true or is there something that I have overlooked. I put the bearings in and it seems that if you pulled on the wheel it would make the bearing ride on the gear. There is no lip to keep it from doing that. How could this be?
Blll Hires
08-11-2002 13:24:08
 Re: Rear axles of Super A in reply to Belinda, 08-11-2002 08:27:28
The rear axle, has a cap screw through a washer, threaded into the end of the axle. A bearing and spacer are behind this washer. This assembly is protected by a pressed steel bearing cap held on the bull gear housing by small cap screws.
