F-12 Gas Tank
Andy
08-11-2002 16:12:20
I have an F-12 that has had gas sitting in it for quite a while and the gas turned to varnish. There a lot of crude along the bottem and clung to the sides. What product can I use to clean this out? Thanks!
Mary Mary
08-11-2002 21:02:57
 Re: F-12 Gas Tank in reply to Andy, 08-11-2002 16:12:20
Try pouring in Acetone and capping off the top and bottom and letting it sit for a day. Believe me, whatever is in there is going to come out.
Justin
08-11-2002 19:06:16
Andy, I went through the same thing with a cub that sat for almost 30 yrs, the tank was a nightmare.Some people reccomended por15 a prduct you can get on the net.I tried s putting a couple gallons of laquer thinner in the tank for a couple days=helped alittle,pressure washing inside of tank ect...What worked for me but you have to be Really CAREFUL is mauratic acid! remove tank from tractor and remove strainer assembly from bottom of tank because it will EAT IT OFF YOUR TANK I found out the hard way!! plug hole in tank with a plug(steel) make sure all gas is out of tank and add acid.Leave in for about 1/2 hour dump out and rinse with gas a couple times,WHATEVER YOU DO DO NOT
