Will wide front from Super C fit on an H?
Boondockjones
08-12-2002 17:13:15
My son has a chance to pick up a wide front-end off a Super C . Would it fit his H, or would it be too light? The price is right so we will probably pick it up anyway. Are we on the right track, or should we keep looking for an H front end?
Haas
08-13-2002 05:49:14
 Re: Will wide front from Super C fit on an H? in reply to Boondockjones, 08-12-2002 17:13:15
The C wide front won't fit the H without a lot of modification. As the others said, the C wide front is not heavy duty enough for the H.
David Ransom - Notice anything odd about this photo?
08-12-2002 21:48:59
No, it's not a fake.
third party image
sammy the RED
08-14-2002 14:47:08
 Re: Re: Will wide front from Super C fit on an H? in reply to David Ransom - Notice anything odd about this photo?, 08-12-2002 21:48:59
It has red rims instead of aluminum.
Since it seems to be a early H, the hood decal should say McCormic-Deering.
And of course, the "C" should be a "H".
don
08-14-2002 02:38:27
Somebody wasn't too familiar with the ole Farmalls were they?
Haas
08-13-2002 05:50:24
No, it's not a fake, just an H with a C decal on it.
Hugh MacKay
08-13-2002 01:48:28
It obviously isn't a C, someone has used the wrong decal. What does the serial plate say? anyone going to trouble of restoring tractor and using wrong decals, would probably switch serial plate.
Another item I notice is hood doesn't seem to be matching front section over radiator. That could be photo.
JD Humm
08-12-2002 17:59:25
We have two SC's with wide fronts and in my opinion you would not be happy with one on an H, I am sure it could be adapted to fit, if not a direct fit. That front axle is pretty light, the front end on the first tractor was all welded and cobbled up, I spent hours rebuilding it, copied it piece for piece. If it breaks up that bad on a SC, I can only imagine what a larger, heavier H would do to it. Of course this tractor had been abused a good portion of it's life but now it is spoiled! So I am sure care is a good part of how it would hold up as well.
Brian Schmidt
08-12-2002 18:59:41
 Re: Re: Will wide front from Super C fit on an H? in reply to JD Humm, 08-12-2002 17:59:25
I would trade it or sell it and make some bucks then buy one to fit your H. I personally would not have a WFE. Too hard to turn and they just look goofy, in my opinion. You also seem to need an acre to turn one around. But, I have never turned one over. If I had, I might reconsider my position.
Steven@nd
08-12-2002 20:08:31
 Re: Re: Re: Will wide front from Super C fit on an H? in reply to Brian Schmidt, 08-12-2002 18:59:41
You would definitaly change your mind if you had hay to make on steep hills and ditches. Also if you ever used a loader on your tractor.
I bet I can turn just as sharp with my Schwartz wide front on my H - that's why they are called "turning" brakes. Although I do like storing my narrow front F-12 and F-14, they take up the same space as my H!!
Steven
SuperCmore
08-12-2002 19:25:24
I agree with you. They are too hard to turn and look "goofy"...sepecially on a Super C. On utilities, they're OK...but not on row crop tractors. How are you gonna get the mounted picker on a wide front H or M with a wide front. Even goofier would be a wide front LP tractor!! Cmore
Brian Schmidt
08-12-2002 20:25:35
 Re: Re: Re: Re: Will wide front from Super C fit on an H? in reply to SuperCmore, 08-12-2002 19:25:24
Most definitely on a utility, but not a row crop indeed. They always seem to sit too high in the front for some strange reason.
BIG JOHN
08-12-2002 18:06:03
Most wide front ends for a H will also fit an M and vise versa. But as JD says the wide front end for a C is much lighter and probably wouldn't be a good idea.
