Chattering voltage and ammeter
BEL @IN
08-13-2002 18:05:47
Just put on a new voltage regulator and still the same. Have correctly polarized and hooked it up as near as I can tell. Ground the field terminal and it puts out max amps steady as a rock.. As usual thanks in advance to all who would care to comment.
Red Dave
08-13-2002 18:49:16
 Re: Chattering voltage and ammeter in reply to BEL @IN, 08-13-2002 18:05:47
Just a shot in the dark, but is the regulator base solidly grounded?
Bob M
08-13-2002 18:48:43
Ben - A bad ground at the voltage regulator can cause that. Try running a ground wire directly from the regulator base to the grounded battery cable and see if that cures it.
Red Dave
08-13-2002 18:51:35
 Re: Re: Chattering voltage and ammeter in reply to Bob M, 08-13-2002 18:48:43
Bob, You type faster than I do! :^)
Bob M
08-13-2002 18:58:01
 Re: Re: Re: Chattering voltage and ammeter in reply to Red Dave, 08-13-2002 18:51:35
Dave - If I can type faster 'n you, it ain't by much!! ...Bob M
