Anti-freze in the oil
bob
08-20-2002 06:49:40
I bet anti-freze in the oil topic on the fergie has been up before, and I am a late starter. I have this problem. I love this old TE-20 tractor but from local advise find this model is famous for haveing cracked blocks. I wonder if any other readers had this problem and solved it.
billv
08-21-2002 08:14:41
 Re: anti-freze in the oil in reply to bob, 08-20-2002 06:49:40
I had a TO-30 ferguson that was doing the same thing and thought that I had a cracked block, thay are known for this problem because the cylinder walls are very thin between the cylinders. I was lucky that when I pulled the motor apart the block was not cracked. The ferguson uses a wet sleeve engine and the o-rings on the sleeves had cracked and rotted away and that was how the water was getting into the oil. I rebuilt the motor and never had any other trouble with it.
Old Hand
08-20-2002 17:09:02
I had a M leaking antifreeze into oil year or so ago. Was able to tell leak was somewhere in bottom of block but was never able to pinpoint area. Having nothing to lose I poured in 2 bottles of Prestone stop leak and put tractor to work after at least 100 hours of real work have had no more sign of coolant in oil and have never had to add coolant to radiator.
