Honing question?
Bob
08-21-2002 09:01:03
I recently rebuilt my farmall h and the new sleeves already came honed. Later I was told I should have used a glaze breaker hone on the new sleeves before installation. Is this true? I didn't hone mine and since I have been having a hard time to get the rings to seat. Any thoughts would be appreciated. Thanks Bob
DHuth
08-25-2002 00:28:58
 Re: honing question? in reply to Bob, 08-21-2002 09:01:03
Dont know if sleeves come honed....another thought is what type of oil are you using? Had trouble with an engine I rebuilt because I was using a Delo type Diesel oil and was not allowing ring to seat into the cylinder wall. Was an L.P. (propane)engine and didn't have the washing affect that a gas enine would however.
Chris Brown
08-21-2002 12:28:42
Keep running it ,I never saw a 30 year old tractor that the rings never seated,HA.it might use a little oil till it's broke in but that doenn't hurt anything
Jim in UK
08-21-2002 09:53:34
It would have been very wise to have "broke the glaze" on the cylinder walls by honing them prior to the installation of the pistons. I have seen this on numerous cases in the past where people didn't, and the piston rings never did seat/seal. The best way I can think to describe this is kind of like applying a fresh coat of paint on to an unprepared surface ... the fresh coat of paint very seldom sticks very well if it sticks at all. There is probably a short cut to remedy this problem short of removing the pistons from the cylinders and honing them out. But I don't know what that would be. Good luck with this query, and if there is a short cut solution to correcting this fault I would sure like to hear it also. I will be leaving the UK in the upcoming months (December or possibly sooner) going back to the states. If there's anyone in Easten New Mexico or the Texas Panhandle needing a hand with restorations, repairs, or maybe a part time extra farmhand or mechanic let me know. I will (hopefully) have a little free time on my hands occasionally and wouldn't mind doing some helping out if someone needs it.
later days mates,
Jim in UK
Aces
08-21-2002 09:52:00
Never honed new sleves in the past but don't how they come now, best way to seat rings is good hard work but don't get it hot. best engines I ever saw were tractors used for demos hard work right out of the box.
