Need help with IH B414 hyd sys
Bill pack
08-22-2002 14:47:01
I have a problem with the hyd sys for the 3 point. It will go up with no load, but if you stand on an lifting arm it will not go up.
Does any one have a suggestion or maybe a hyd drawing for the sys. This tractor is made in England.
Thanks, Bill
Dale O
10-21-2002 10:36:41
 Re: Need help with IH B414 hyd sys in reply to Bill pack, 08-22-2002 14:47:01
I don't have the answer for you, just the same problem and wondered if you had yours cured yet and how. My problem is the draw bar will just barely lift with no load, will not lift when standing on it. (Tractor does not have power steering or loader.) Crack line at hydrualic pump and get a trickle but no pressure, but it is not a pump problem as this pump was put onto another tractor and has great pressure.
Seeing Red
08-23-2002 02:48:02
We have one that does something similar, but will raise with more throttle. We didn't have that problem until we installed factory power steering. Does yours have power steering by a chance? The pumps on those tractors I think only put out about 12-14 gpm. Maybe possible a relief valve partialy stuck?
