1951 Farmall H
electrical problem
André Bordeaux
08-23-2002 12:35:01
Original 6V positive ground system. Starter will not engage. Took starter on bench direct - works fine. Had this rebuilt last year.
I noticed that my battery would not hold a charge lately so I bought a replacement and lo and behold it also drained down. I noticed when hooking up the newly charged battery that the connection sparked. Something component or connection is allowing a short. Would anyone have an idea of what I could check? Thanks
Bob M
08-23-2002 13:18:59
 Re: 1951 Farmall H - electrical problem in reply to André Bordeaux, 08-23-2002 12:35:01
Andre - The cutout contacts in the cutout relay or voltage regulator (whichever your H has) are stuck closed. Replacing the cutout or regulator will correct the problem.
Farmall Don
08-23-2002 13:15:50
I had that problem with my M and replaced the ground cable. That solved my problem.
