SAE 160 transmission oil
Bruce
08-26-2002 18:33:09
Anybody know if SAE 160 transmission oil is still available? If so, where? Any help would be appreciated.
Doug in OR
08-26-2002 18:38:35
 Re: SAE 160 transmission oil in reply to Bruce, 08-26-2002 18:33:09
Personally, I wouldn't bother looking for it. The 140 oils of today will withstand pressure tests far better than the older oils. I'd even go with 80W-140, and bet it would outperform the old single grade oil.
Bruce
08-27-2002 03:46:42
 Re: Re: SAE 160 transmission oil in reply to Doug in OR, 08-26-2002 18:38:35
Doug: Thanks for you input. The reason I'm looking for SAE 160 is to use it to slow down seepage running down the inside of the axle plate on my F30. I do not plan on pulling this thing apart to replace seals, gaskets, etc. Too labor intensive. Ive heard that some STP additive could be added to the 85-140 that I have in it now that would help slow it down. Any ideas? If not, I guess I'll just keep wipin the grease off.Other than this problem, it's a great tractor.
