350 rear main seal replacement
Brian
08-31-2002 19:16:45
Can the rear main seal on a Farmall 350 be replaced by just removing the oil pan and without splitting the tractor (can you push the upper half of the seal in) or is it in a special housing that requires you to remove the flywheel--splitting the tractor? Thanks for any and all info.
Jim in UK
08-31-2002 19:30:48
 Re: 350 rear main seal replacement in reply to Brian, 08-31-2002 19:16:45
I have never worked on a 350, but from the information, and knowledge that I know. If I were you I would plan on spliing the tractor.
joe
08-31-2002 19:43:26
 Re: Re: 350 rear main seal replacement in reply to Jim in UK, 08-31-2002 19:30:48
I think you can replace the main bearings without splitting the tractor, but must split the tractor to replace the seal. Someone else should verify this.
