PTO for Super A won't engage
Al R
09-01-2002 05:47:19
I purchased (used) a PTO unit for my 53 Super A. I installed it and it will not engage-just chatters when I let the clutch out! I took it back off and the shifter shaft end looks like it won't mess with the female spline gear in the transmission. Did I get the wrong shaft in the deal? Thanks ahead for help. Best Regards Al
Lewis
09-01-2002 18:28:45
 Re: PTO for Super A won't engage in reply to Al R, 09-01-2002 05:47:19
Steve, If memory serves me correct, there are two different tubes that slide over the pto shaft that actually engage the pto. I believe the shaft itself is the same, but they changed the tube that engages the gear in the back of the transmission. Hope this helps!
Al R
09-02-2002 06:59:47
 Re: Re: PTO for Super A won't engage in reply to Lewis, 09-01-2002 18:28:45
Thanks Lewis, That helps, the tube that slides (to engage)over this shaft has (2)two teeth or prongs, cut on an angle. This angle would allow the rotation of the transmission gear to turn the sleeve and shaft. If the tube and shaft rotates the other direction- it would push back and I guess disengage. The gear in my transmission case is female spline- about (8)eight splines I guess. Do you remember if there is a smaller spline/connector to mate them up? Or do you think I need a different shaft? Thanks again.
